Originally Posted By JohnRR
Originally Posted By His and Her 69's
Yes the engine is the original one for the car with the VIN on the oil pan rail. All the parts should be original as we never changed the main parts just the wearable items. points, cap, plugs, water pump, etc. The 4 sp has the Vin on it etc. The carb did get changed to a 70 440 carb over the years.
I just can't find the water pump housing.
The Vin is RM21H9A1782--
the bottom line has the 825 066049
Looks like it will be this weekend before I get more numbers, just not enough time in a day.
The intake has a double digit for the day, I just can't read the second digit. I will see about getting a photo of it.
Thanks Guys.
Something does not add up here , or that car somehow slipped into a hole somewhere ?
The car was SCHEDULED to be built on 8/25/68 but the original engine was not assembled till 11/18/68 ???????
David (OP), JohnRR is correct. The SPD does not match your VIN at all. Your VIN works for the dates you are discussing about the engine. Is it a B25 on the tag? This would be a November 25, 1968 date and would make more sense.
If you share your fender tag, there are other numbers on the Lynch Road tag correlating to SPD and VIN. PM me if you don't want to post it.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
