Good luck im on my second turbo build. Take your time and do it the way you want. Its easy to buy parts and change your mind so do your do diligence and make sure when your buying your parts its what you really need. Give us a run down on the parts and pieces you have in mind to use and im sure we can help you in any way possible Heres my 62 valiant with a 400 mock up block anything can be accomplished
Check out my build on Facebook Ttoad Hurley its updated regularly
