I had to remove the pitman. I removed the nut and got all of the rust and grease off of the splines so the the Acetone mix could penetrate. I was careful not to squirt the stuff everywhere because I wanted to see how it would go through when I squirted it on the nut side. After about a half hour the stuff started running out of the bottom side towards the steering box.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
