Originally Posted By gtx6970
1/4-20
http://www.mcmaster.com/#weld-nuts/=zs6ca9
no 10-24 avail anywhere that i know of
If SQUARE 10-24 nuts were needed, either fabricate them, or remove them from floating weldnut assys, or peel off the cage from cage nut assys depending on the height requirement of the nut? as the nuts vary in height depending on the assy type, standard SAE square 10-24 nuts are only .125 (1/8) in height
