Hi Ron when it comes time for the nut cutting Dwayne will definate be the one that does the cam. I am just looking for performance examples and trends. The combo will be the new trick flow heads with the A&A cnc ported 440 intake 3705 afb carbs, 11 to 1 compression and tti 2" headers. 4200-4500 stall and 4.10 gear. It will all be going in a 63 savoy. Hoping for a 3500 to 3600 lbs with me onboard. I weigh 200lbs
Getting old just means you were smarter than some and luckier than others.
