Quote: Have you figured out what to do with the battery tray yet? I looked at mine and it looks to be the same way. I havn't put a battery on it to check though.
Right now we're leaning towards adding a 1/2" to the battery tray bracket and oblonging the tray bolt hole where it secures to the rad support. This will lift the battery a 1/2". It will clear the hood and be level. This is the easiest solution right now without doing major work. Were holding off doing this and working on other things, just in case we come across a better solution. This can be the last thing we do anyways.
