For the goodmark quarters and flip top caps you can grind the 4 corners on the bottom of the flip top housing at a 45 deg angle and it will fit flush (after its painted )try this first using you old flip top housing. It took me 10 min to make this fit. I got one of the early sets and IM surprised they have not fixed this issue. Remember to fit up the flip top with the trim ring.
