Im running the 28x9x15 radials, no et or speed difference from the m/t bias ply of the same size on my small block dart. 7.20 1/8 mile car
how do you find traction ? what weight ?
thanks
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
