Originally Posted By Cab_Burge
Don't forget to make SURE your factory wiring and amp gauge will handle the increased amps SAFELY scope We don't need to read a post from you or anyone else on here about having a wiring meltdown or burnt up car from melted wires catching on fires shruggy
THIS.........All of my 12 v wires tie into the main post directly from the batt. and are wired around the stock loom. Only my headlights, taillights and blinkers run through factory wiring.......Good call Cab......
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
