Originally Posted By 440_Offroader
Another option for your pinion angle... have a driveshaft built with 1350 CVs on both ends. I had this done for my 79 Macho with full time four wheel drive. I only have a few thousand miles on it, but seems to be holding up fine. Just a way of not having to worry about cutting,welding,caster angles, etc.
I never considered that. Does it require a pinion yoke change?
