A line lock is a solinoid that stops the fluid from being relesed. It's location depends on what you want to use it for. Placing it in the rear brake line you use it as a staging control and luanch when you release it. I have mine in the front line and use it for doing burn outs. Then there are people the run dual linelocks.
