Check the CHMSL. IIRC, there was an issue with those that caused leaks. Cant remember what the fix was though. Maybe the gasket?
Here's a good way to check for leaks - start the car, put the heater/blower motor on high and close all the windows. Get a spray bottle of soapy water and spray around the rear window and third brake light. If you see it bubbling somewhere, there's your leak.
'71 Duster
'72 Challenger
'17 Ram 1500
