When using a CD ignition. The ballast resistor is no longer used.
You have the ignition ON wired into a circuit that is only on during the key on position. You need it wired so you have power to it when ON and in CRANK position. Most circuits go dead, when the key is in CRANK position.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
