I have never seen how a superbird is put together.
I would start touching that ground wire further away from the bulb till you stop getting lights, then see what holds the housing to that part of the frame.
scrape there.
it will be as robert says, some kind of screw or bolt holding the housing to the sheet metal, as everything else that touches should be against a gasket.
