Thanks for the kind words, the car has always been a work in progress.
I used to run a single 118 mm turbo before with victor heads on the same shortblock, made 1550 rwhp and ran 7.90 all day with ease.
Hoping to get a 1.15-1.18 short time out of it when its turned up. I need to add more bite to the car off the line as it spins before it lifts the tires on initial hit. Usually was launching at 4800 and 4-5lbs boost and it seemed to like it there, 5000 is a little much.
Tires are 33x16-15 hoosiers, I've also ran the 33x18.50 ET streets with good results also.
All in boost didn't matter between 14-20 lbs for ET. It drove through the converter faster with 20 lbs so we just left it around 17-18 so it didn't put too much heat into the trans. Will be nice to see RPM drop and it to pickup ET and MPH when it actually starts locking up harder.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
