Just for the record...I ordered the K7075 which is for the 73-74 e-body's and it worked fine. Exactly the same as the 72 power steering model, but with the smaller hole to fit the manual output shaft. It should work fine with the 70-72 e-body with manual steering. Hopefully this will help someone in the future.
