Quote: Any idea how many L's and J's you ordered. I would love to have enough on hand to do it all at one time without having to re-order.
-Dave
It sortta depends on what you have to clear but on most headers that I build I figure 3 J bends per tube but you also need to know what radius's you will need, on some pipes you may have a couple of different radius on one pipe(for clearance).. try to use the largest radius that clears(they flow better) and the fewest bends possible... again they flow better
I'll look at my receipt, and count them up. I agree with what's mentioned above. Some 45 degree bends would have been nice, instead of using 90's, or cutting and welding to make a slight bend.
