Some years the back-up light switch is mounted on the push-button control box and possibly the starter switch is in with the neutral button, that is the only electrical connections you should find.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
