440 with XE268 cam, Holley SD single plane intk, 727 with 3.23... Running an early Tq 6518S with normal idle screws (orig had holes in them) and with orig 2124 top. IFR drilled to 0.038" and then a 0.010" wire in the IFR. Idle mixture screws 2 turns out. Initial 22 degs with 11 degrees in distributor all in by 3,100 rpm. 18 degree vacuum advance can about 3 turns out.
0.098" primaries with 2024 rods about 3 turns from bottom. 0.143" secondaries. Oh, using inlet needles that will pass a 7/64" drill bit. Air door about 0.7", 1.5 turns. 0.028" pump shot on the slowest setting. Getting about 14 mpg on Shell V-pwr.
