Could I mount a 1" hub centric spacer that has integral studs to the wheels and use that as the centering device?
Any thoughts?
I would think that the hub centric spacer would center the spacer on the hub/drum cuz the center hole of it would fit tight on the raised register and the lug centric spacer with the right lug nuts of course would center the wheel on the spacer. there oughta be an easier way than fabbing one of those up tho. Can you use some 1" (wrench needed) racing 1/2" tapered lug nuts to center the wheels as is?
