i wouldn't hessitate & go with the 1.6 ratio. it'll make you cam think it's bigger when you stab your foot on the loud pedal. all my motors have 1.6 ratio, never seen a bad point on running them. the HS rockers may cause you to loose oil pressure a little when hot but thats what you get with roller bearing rocker arms. go for it, don't look back.
