I figured I'd throw in these numbers too....
452 heads with 2.14/1.81 valves, done by a well known mopar
volume head rebuilder, no porting, no blending. To the best
of my recollection, these are the worst flowing big valve heads
I've come across. They had a big "bowl hog" type cut done under
the valve job that really hurt the flow. IIRC, these flowed less than a
completely stock head with the OE valves and valve job.
Lift------in/ex
.100----67/52
.200---118/97
.300---169/129
.400---196/141
.500---217/145
.600---222/145
Bowl hog? Is that like running a 70° stone as far as you can take it? If not porting, how should it be done when installing bigger valves?
