When I see BIG starting numbers like this it raises LOTS of questions about flow bench calibrations.
.100...............73...........................73
.200..............151..........................152
.300..............214..........................218
.400..............245..........................267
.500..............262..........................308
.600..............276..........................337
.700..............281..........................346
I have had a lot of Stealth heads on my bench and when I test I test EVERY port on every head. The most I have ever seen was 267cfm. Start with high numbers end with high numbers and those in the know, know better.
This! ^^^
I look at it this way: I see 9 out of 10 very good head porters have results within 10 cfm of each other. Then I see one guy with results that are nearly double that of the other guys. Who is the outlier? Or, am I to believe that Dwayne and the other head guys here are a bunch of know-nothing hacks?
I had Jeff's/MCH Eddy's checked on a local bench and the numbers were within 1 cfm of each other. Trust, but always verify.
