What wear marks would there have been on the VIN tag? The only wear marks that I would imagine being there would be from trying to drill it out and the rivet spinning. If that is the case, it could have started wobbling ever so slightly when it was spinning in the hole. That itself could be enough of a variance to give you that .01 difference.
