Originally Posted By R5P7Duster
Sounds like you have a lock up pump and non lock up convertor. Or vice versa. It will almost seem like you have a trans brake and you have to rev it up and then it will hit.
I made this mistake before, scratched my head for weeks.
The pump I put in it worked fine in the first trans... that
trans we forgot a torrington bearing in the OD and after about
400 miles it ate up the OD drum... so that pump worked.. I
got it from Cope.. and I picked up another pump from him for
my spare trans
wave
