The adapters to mount generation 1 Viper calipers to 73+ disk brake spindles on 11.75" rotors?
Viper calipers on B-body rotors will require a spacer behind the brake pads.
Viper calipers on C-body/D150/B150 rotors will require a different outer bearing. I haven't dug around to see if the bearing exists or if a spindle sleeve will be required.
Either set will require careful measuring to be sure the caliper will not contact the wheel.
I think Dr Diff bailed on this application due to low sales.
Building the parts isn't hard, it just takes a little time on manual machines. I've done more challenging conversions.
![](http://image.hotrod.com/f/9166458+q80+re0+cr1+ar0/0711phr_07_z%2b1965_plymouth_belvedere%2bwheel.jpg)
