Originally Posted By okie
Which lifters will pump the most oil up the push rods ? On a 70 383, don't ask. I have a problem on my block and I have to run hollow push rods so i need a set of good pumping lifters in it. Which ones pumps the best. Thanks
I didnt think the lifters pumped up any oil.. just the oil
pressure... but I dont know much about hyd lifters... I am
use to solid lifters
wave
