[quote=Chris'sBarracuda] When I had my Stage 6's I had rocker issues until I added these
and changed the studs to 7/16"
Another stage 6... pulled the threads, bent broke the shaft. the heads weren't drilled deep enough for a longer bolt/ more thread engagement. Fixed it the same way as Chris.
