Re: Rebuilt engine, no compression, spitting gas, help
[Re: sco440]
#1882635
08/01/15 01:29 AM
08/01/15 01:29 AM
Posts: 43,335 Bend,OR USA
Cab_Burge
Who rebuilt it? If you did the build did you install the cam with the dots on the gears or did you install the cam and and degree it? If with the dots on the gears did you aligned the crank gear dot out under the teeth or the one on the inside above the crankshaft key? If the one above the key you need to use the one on the outer edge of the crank gear. If you didn't do the build call the one who did and tell them to come fix it Let us know what youy find and do, it will help a lot of others on here also
Entire Thread
sco440
07/31/15 10:19 PM
Challenger 1
07/31/15 10:29 PM
smos001
07/31/15 10:30 PM
stumpy
07/31/15 10:42 PM
RapidRobert
08/01/15 02:38 AM
Kern Dog
08/01/15 04:45 AM
lewtot184
07/31/15 10:32 PM
smos001
07/31/15 10:40 PM
Cab_Burge
08/01/15 05:29 AM
sco440
08/01/15 07:38 PM
Cab_Burge
08/01/15 10:18 PM
RapidRobert
08/02/15 05:45 AM
70Cuda383
08/02/15 06:41 AM
