" You can do far more with the Procomp casting than an Edelbrock casting" - where is the difference ( besides being able to run longer valve stems )? Do you have a specific CNC program for these heads? Do you have ported flow numbers? Why 68 CC chambers OOTB? Thanks, John
Fastest 300
