Some how we have gotten to the point where guys making 600 real HP (as the OP says he is) don't think they need an aftermarket block. Not only is reliabilty down using P car blocks so is your HP. Your tune up window is significantly reduced, so a minor tuning error will cost you big time.
If you can't afford/want an aftermarket block, think about a reduction in HP and RPM. What you are using was never designed to have done to it what you are doing. All the tricks in the world won't help that.
That's all good, and I agree! But, aftermarket blocks for us mopar guys are not just sitting on part supply shelves. Plus their are not many choices.
Sometimes it comes down to availability and reasonable cost.....
We all understand that and that is part of the dilemma of being a Mopar guy........but you drop several thousand prepping a stock block with the machine work, caps, girdles, whatever your bandaids are to fix it and it still cracks within a couple hundred passes or less. It's all up to each individual whether they are willing to gamble or not. Some last, many don't
