Guys,
I have been reading some of the more recent posts on here about the shortcoming of the Lokar kit namely that the ratio on the carb lever does not match the ratio on the kickdown lever causing the kickdown to be almost unadjustable.
I have the Lokar kit and I want to stick with it. I know Bouchillon has their version which is supposedly better but I don't want to pay 125$ for that right now...please don't suggest that.
The issue I am running into now is I can adjust to the point where the tranny kicks down at WOT but then the tranny won't upshift from 2nd to 3rd at light throttle until I let off the gas entirely. If I adjust it the other direction to the point where the tranny shifts properly at part throttle, it isn't far enough to kick down at all when at WOT.
I have read that you can make the ratio more correct by drilling the lever inward a bit to re-locate the stud thereby reducing the ratio.
Can somebody give me a rough idea how far in I should drill to move the stud in? I know this isn't an exact science but I don't want my lever to turn to swiss cheese doing this!
Any ideas would be appreciated. You can use my photo and make a dot where it worked for you maybe? <img src="/ubbthreads/images/graemlins/thumbs.gif" alt="" />
PS carb is a Holley 4150.
Not a great picture. I took a old throttle pressure lever and mounted it onto my linkage. I can now slide my pivot point up or down to get the stroke right. Might not look so great but works for me.
Better picture.
