anytime stroke is increased beyond stock ring wear is increased due to more travel. the increased wear can also be a factor of lower gears increasing rpm and i have noticed that the more power the engine makes (loads the rings) and the more often the power is used the shorter the ring life. but, i do think there are ring materials that can help with wear in a performance application.
