I'm not an ethanol fan, but if your blend has been working, stick with it. IMO, you want to run just enough of an octane # so you don't have to compromise timing to stay out of detonation. I probably play it a little on the safe side, but 21 lbs of boost in the lights equates to a pretty scary static CR, so I run 110 - and some windshield solvent.
