next you will want to bend the tabs out 90* I found placing them in vise with jaws clamped as far up the tab as I could get them to bucket mount surface worked well they bend easy and even this way, repeat this for all 4 tabs on each bucket, at this time you can drill holes on out side end each of the four tabs, you will need these holes to mark the drilling points in the rad support to mount up buckets.
