Yes, you can move the buckets over a bit, perhaps drill new holes for the mount screws. The best thing to do is to measure measure measure!
For my trucks (and I've had a bunch of these over the years), at some point early on I decided to simply stay with matching parts, no easy task up here in the rot belt. Even when I went from the twin round headlights to the stacked quads on my 79, I replaced everything including the core support.
So, in a nut shell, yes, you can swap these parts. You just need to do a good job of layout. Have it it!
