Originally Posted By HemiSportFury
That's exactly how I have done it. You need the full weight of the car setting on the springs to set it correctly,
Oh OK so I was off base thinking of doing it with a bare housing. I will go ahead & finish assembling the 8&3/4 then mockup loaded as you said. Thank you both!
