MORE
More what...? You think the chain might be off more than a tooth or two?
That is a easy enough fix, but I just hate to pull the whole front end off again....
When a chain jumps a tooth you can make it run by changing the timing but it will have no power. It will act like yours sounds. Not saying that you got it off but I would suspect it as you have just had it all apart and changed the cam. I would hate to pull it all apart also but if all else fails that is where I would look.
