I know this might be a stretch but what are the odds of the seal journal on the crank not being in line with the rest of the crank? or the other way. the crank seal retaining area not in line with the line bore? i wouls at least try to check that part on the crank, seeing that that might be the 1 thing that has changed in the previous setup.
