I have heard deep staging will slow your ET around a 10th. I am not sure it still is but deep staging use to be illegal. Back in the 90's when 6.0 and 7.0 first started nobody was running a transbrake and one guy would do a burnout past the starting line then back into the lights. That is as deep as you can get. That is when they banned deep staging.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
