Ok , my best ET this year was a 6.21. I have been thinking about trying index racing at one of my local tracks. They have 6.0,7.0,8.0 and 9.0. I am too slow for 6.0 and wondering if I can slow down enough to run 7.00. I would think I need full throttle to cut a decent reaction time on the 4 tenths pro tree,I am foot braking. This Wednesday I am going to T&T and try to figure out if I can slow down enough to run 7.00. Is it possible to lower my shift point enough to run 7.00. I shift at 6800 rpm now and I have a 5800 rpm chip I am going to try. Does any body have any ideas?
What were the conditions when you ran that BEST ??? if it was mineshaft type conditions I wouldn't use that as the gauge unless that is always the conditions .
Me ... I would add weight, held securely of course, and run it out the back door. You can always remove a little weight to go faster if needed, and lift a tad if you are ahead just before the stripe.
I did it my way because I was racing 2 classes and
needed to change over in short order... weight was to
much of a problem... I could change the throttle stop
in less than a minute.. then it was change the rpm points..
this also allowed for the car to pick up if needed.. just
hold the shift rpm a little higher... if you have weight and
your slow.. your screwed(if during competition)
![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
