Sounds more like a ignition coil failure to me. The box only controls current to the primary winding's of the ignition coil on or off. That timing is controlled by seeing the signal from the distributor pick-up at various rpm. I doubt if it would fade with, more likely with RPM change. If the ignition coil is getting proper voltage I'd swap the coil. Coils are susceptible to heat failure.
Doug
