A&A and ProTrans are the same one. I had one and it worked awesome.
You sure about that?
A&A is out of the Indy area and owned by Rick Allison. As I said earlier, I think that is what CRT uses.
Pro trans is out in California and does a lot of the Mopars super stock stuff. I thought he made his own stuff?
Was told buy Rick that him and ProTrans spilt the orders when they get them made. I have had both Pro trans and A&A valve bodies, only difference is pro trans makes the plate gold and Rick leaves his black. Yes crt also gets valve bodies from Rick.
Kinda surprised that is the case. Protrans says on his site his valvebody's are made right on site. Learn something every day..... Interesting.
Edit.... Went back and reread his site...... " inhouse designed and assembled"......... Guess that leaves some wiggle room for " made" there...... Kinda misleading statement , fooled me.... Lol
Yes Rick and him design the valve body together and each make updates to the process. They are also each assemblies at there own shops but with all the same parts and pieces to help control production costs.
Rick told me they share a lot of hard parts, so they can keep quality up and costs down.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
