Originally Posted By B3422W5
Originally Posted By 1967dartgt
A&A and ProTrans are the same one. I had one and it worked awesome.
You sure about that?
A&A is out of the Indy area and owned by Rick Allison. As I said earlier, I think that is what CRT uses.
Pro trans is out in California and does a lot of the Mopars super stock stuff. I thought he made his own stuff?
Was told buy Rick that him and ProTrans spilt the orders when they get them made. I have had both Pro trans and A&A valve bodies, only difference is pro trans makes the plate gold and Rick leaves his black. Yes crt also gets valve bodies from Rick.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
