Hi guys looking for an alignment shop in Jacksonville FL, that can do something older than 93 and is good at road race setups on older cars, asking if they can do an alignment for a volare or aspen they just kind a look at you like you're crazy Thanks,
-Mike
Find out where all the fast Mustang drag racers are going to get theirs done. These guys are using non stock specs and have had adjustable strut rods available to them for decades, so anyone who can set up one of these can do an old mopar.
(2) turn all (4) cams till you get max caster
F bodies don't use the older cam style adjustment. They are more like a GM with the arm bolted into the sub-frame on a serrated plate. You can get much better specs out of them without using special bushings or arms.
Even this is a bit outdated. By using higher caster numbers, you can reduce the static camber while improving the dynamic results.
