It looks like you just need a Rally Hood for a 1970 Challenger and do not care for the OEM look to match the 1970 Challenger factory hood. There are many differences in a 1970 Hood than the rest of the years. Most are NOT seen when the hood is shut. The D.O.D.G.E. is the most noticable. Hood latching is different, Hing bolts, no cruch zones. If you do not get what you need in a template, I will take some measuresments off the extra 1970 Challenger Rally Hood that is hung on my wall in the garage when I get home on Monday if no one post measurements. Not sure if the AMD Challenger Hoods come predrilled for the engine name plate either.You might want to ask for those hole locations also.
