Those comp lift #'s are for a 1.5 rocker. Not sure what you are running,
I am running CompCams 1.5 rocker right now...but I have a set of Crane iron 1.6 ratio rockers...was thinking of trying these out actually...that would already get my current cam into the .571/.576 range...which is proably as big as I'd dare to go.
...The HR will also have more lift under the curve than the hughes is my guess...
You know, this was my thinking behind the 'hydraulic roller test'...LOL...yeah, I wish we could get a graph of the actual cam lobe profile that shows the lift vs degree rotation. Maybe there is a poor-man's setup that could be used somehow? The lift would be easy to track, just not sure how to track the crank rotation...can't think of an easy way without having to pull the timing cover off and tossing a degree wheel on...
