There was a change in the Magnum motors. When they went to the later engine controller the plugs on many of the sensors changed shape. You can't plug an early harness into a late engine.
I do not know what year that was done.
Make sure the Dakota and van engines use the same plugs if that's the route you take.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
