![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
All of the cheaper rods need to be checked thoroughly by your machinist. All brands of rods should be checked regardless, but the lower priced rods like Eagle, Scat, etc., will most likely need to be resized right out of the box due to poor machining at the factory.
They ALL need to be sized (not resized) OOTB. Saying it's poor QC is a misconception.
They all come honed so they can fit the smallest .990 pin on the market. There are several .990 pins on the market none of them are .990".
If the smallest brand pin is say .989" and the biggest is .991", all it takes is a rod hone to make one part# cover all .990 pins.
Kevin
