First what suspension on the rear and what shocks on both ends..
if you can loosen the extension on the rear shocks so the back lifts
more.. then I would build a adjustable limiter for the fronts.. I
also like to use a valve spring on the limiter so it doesnt slam to
a stop and up sets the chassis.. start with very little front movement
and work your way up.. if you have a 4-link in back you can dial most
of it out with adjustments on the bars(use a real short IC so it lifts
the back of the car and not the front)
![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
